Does anyone know if the vera plus controller support the new fibaro button…?
Got mine today. Added as a generic device and it’s not responding. Will have another play later on and report back.
No further along i’m afraid.
Had a play with categories and sub categories to get it recognised as a switch but no luck. Vera detects a state change but can’t interpret it. Ive got a call in with support but its only just been released so I would expect it to be a while until it gets some attention.
Too bad just ordered mine hope vera will support it soon… let me know if you have any progress with it.
It would appear that the Button does not conform to the Z-Wave command class structure that allows Z-Wave devices to be plug and play. That is becoming more and more previlant with Z-Wave Plus devices. Usually you can get limited functionality if you pair via the standard method vs the secure method.
I have mentioned this device to the Device Integration Team.
So i’ve made a bit of progress and its thanks to Versternet support. Shoutout to Jonatas.
He suggested changing it to a scene controller.
Device_type: urn:schemas-upnp-org:device:SceneController:1
Device_file: D_SceneController1.xml
Device_json: D_CentralSceneController1.json
and reloading the luup engine.
I now have a partially working button. It doesn’t recognise the multi presses but at least I can use it a bit now.
If i get any more functionality out of it I will let you know.
thanks
now vera recognizes state change of the button but it wont run the scene
any idea ?
Ive got it working with two out of the 6 actions
1 click and 2 clicks.
On the scene setup pick the button as the trigger and then when it asks for the scene controller settings I picked the following.
Whenever Fibaro Button…
A scene is activated
Which scene number
1
How is the button pressed
The key is pressed 1 time.
The button always works on scene 1 and then key presses after that.
[quote=“Marc Shenker, post:5, topic:193627”]It would appear that the Button does not conform to the Z-Wave command class structure that allows Z-Wave devices to be plug and play. That is becoming more and more previlant with Z-Wave Plus devices. Usually you can get limited functionality if you pair via the standard method vs the secure method.
I have mentioned this device to the Device Integration Team.[/quote]
Marc, I am not meaning to be rude here. But why is it that most of the competitors DO support the new zwave devices fully and fast, fibaro, zipato, domoticz? At least all stores selling these 3 including vera have the support selected for all but not vera…
How does this align with the zwave device support statement from vera?
Thank you.
thanks indymax84 but when pressing i see device is changing state on the alerts but not triggering the scene
Can you post a screenshot of your scene settings?
the scene screenshot
actually 1 press works sometimes but double click wont
as i have 2 buttons i assigned 1 to unlock by 1 click
and the other to lock on 1 click
sometimes it takes more than 1click once to operate
the alert say lost connection with the device
then it looks like 1st click wakes it and 2nd click triggers
but double click accepted as tampering attempt
since the buttons wont fully function right now i dont mind using them just 4 that
still double click would double the limited usefulness ![]()
thanks
That looks right to me. My button shows the same alert but does seem to work with separate 1 and 2 click scenes.
had the sam problem with Fibaro Button. Sometimes the button reacted to press sometimes not. It seems a design fault because the button part (knob) sometimes stops before it reaches the micro switch inside the knob. I just took a sandpaper and shortened the bottom part of the knob by 1/2 millimeter and now I can clearly hear the micro switch klick when I press the button.
Hope it helps with strange behave of The Button.
[quote=“indymax84, post:8, topic:193627”]Ive got it working with two out of the 6 actions
Which scene number
1
The button always works on scene 1 and then key presses after that.[/quote]
Thank you - it helped me get the button to work with a scene. ![]()
Hi Marc, as we are now over a month on, are you able to offer a rough timescale for when this device will be properly supported please?
I am also wondering when the button will be supported.
Anybody have an update to when the button will be supported by Vera? I can’t even get it to activate a scene…
To those who have managed to get it working, do you have it working on single press EVERY time?
I want to put one in my bathroom to enable “bath mode” to ignore the motion sensor for the lights and turn my towel rail temperature up.
