Hello all,
I recieved the fibaro 3 in1 sensor:
[url=http://www.vesternet.com/z-wave-fibaro-universal-door-window-sensor-5]http://www.vesternet.com/z-wave-fibaro-universal-door-window-sensor-5[/url]
Manual:
[url=http://materialy.fibaro.com/instrukcje/instructions_EN/door-window/DoorWindowSensor%20%20FGK-101-107%20ENG%20v12.pdf]http://materialy.fibaro.com/instrukcje/instructions_EN/door-window/DoorWindowSensor%20%20FGK-101-107%20ENG%20v12.pdf[/url]
And according the documentation you can use it as a scene activator , but as usuall the documentation from fibaro is well… not so good and I have difficulties understanding it.
The idea is to use the 3in1 sensor as a doorbell activator , when pressing a springloaded button connected on this device it should activate a scene.
For the moment I connected just to wires to “ground” and “in”, connecting them should do the trick for testing purposes. I also connected the DS18B20 temp sensor to the device. ( not sure if it works correctly, it keeps on showing 23 degrees , and it cooled down here now to 18 degrees ?!?!?)
Anyway , most important is that it can activate a scene, I inserted parameter 14 to 1 and parameter 3 to 1, see attached screenshot.
What next?
how do I tell a scene when I push the button it should activate that scene:
here a copy paste from the manual:
Scene activation functionality.
Default value: 0
Available parameter settings:
0 - functionality deactivated
1 - functionality activated
The device offers the possibility of sending commands compatible
with Command class scene activation. Information is sent to
devices assigned to association group no. 3
Controllers such as the Home Center 2 are able to interpret such
commands and based on these commands activate scenes, to
which specific scene IDs have been assigned. The user may
expand the functionality of a button connected to IN input by
distinguishing the sequence of it being pushed. For example:
double click would trigger the ?goodnight? scene and triple click
would trigger the ?morning? scene. To fully use the possibilities
offered by the parameter no.14 it is recommended to use a
momentary or a toggle switch (parameter no.3).
Scene ID is determined in the following manner:
IN input:
Switch from ?off? to ?on? ID10
Switch from ?on? to ?off? ID11
Remaining IDs are recognized correctly if the value of parameter
no.3 was set to 2
Holding down ID12
Releasing ID13
Double click ID14
Triple click ID15
Hopefully someone can share some light.
One more thing , When I bought the device I thought it is a doorsensor ,temperature sensor and a binary input all together ( 3 in 1), but when I test the device I think it is OR door sensor , OR binary input . Also the tamper switch is a bit vague , not sure if it works :-s
I think Fibaro should hire a new ( and better) manual writer :-s
Thanks for the help,
Cor
