Sensor is reporting status reversed. Door is open but the sensor show it is closed and vice versa. It is also sending me notifications when I didnt set it up to do so in this one. I had one that was non functional so I rma d it back ti the company. They Sent me a new one and now it is giving me notifications that a door/window is open. Any ideas?
There is a parameter in configuration settings which is responsible for setting if the sensor is NC (reporting “close” when the magnet is near the sensor) or “NO” (reporting “open” when the magnet is close to the sensor).
For Sensor 2 it is parameter 1.
[quote=“kwieto, post:2, topic:197263”]There is a parameter in configuration settings which is responsible for setting if the sensor is NC (reporting “close” when the magnet is near the sensor) or “NO” (reporting “open” when the magnet is close to the sensor).
For Sensor 2 it is parameter 1.[/quote]
Yes I finally figured this out by reading the fibaro manual online. I was able to delete that parameter and goto parameter 2 and set the led indicators to be visual
variable 2/ data size
Configuration settings
Variable Data Size Desired Value Current Value
2 1 3 3
Are my settings
