FGS221 wiring question
Heyya.
Could someone please clarify exactly which wires to use for this double switch? I’m pretty sure the yellow is the switched live as each switch has another switch elsewhere.
Can I simply blank the red and use the yellow in S1 and S2? Will this mean that I will only be able to use the Z-Wave switch if the other switch is on? Should I really just replace all the switches with Z-Wave ones and not use the switched live?
Thanks :slight_smile:
