Hi
I have a problem with my new FGFS-101-ZW5 v3.3 device, it is included but when there is a water leak it does not change anything on the dashboard. I tried inclusion in FGFS-101, then in FGFS-101-gen5 and generics but it doesn’t change anything. Do you have this problem?
solution found thanks to @amdokamal and @mdg
device_file:D_GenericIO1.xml => D_FloodSensor1.xml
device_type:urn:schemas-micasaverde-com:device:GenericIO:1 => urn:schemas-micasaverde-com:device:FloodSensor:1
manufacturer:Fibar => Fibaro
model:empty => FGFS-101 Gen5
device_json:D_GenericIO1.json => D_FloodSensorWithTamper1.json
category_num: 4
subcategory_num: 2
the device works correctly for water leakage, armed state and temperature. I do not see the state of tamper.
I can use it in scenes and the notifications are correct. I included it in FGFS-101 gen5 by performing a triple click on tamper and I changed the parameter 78 to set it to 0
