Feedback from GC100 (WF2CC)
Just starting out with all things Vera and enjoying the ride so far!
I would appreciate some guidance if anyone can point me in the right direction.
I have UI5 running on Vera-lite. I have successfully installed the GC100 plugin and Im able to control a global cache Itach WF2CC unit. I would like to be able to get feedback from the WF2CC unit to ensure command success. I know that using the “getstate,1:1,0” ASCII command the unit will respond with state,1:1,0 or state,1:1,1 depending on the state of the first contact (command “setstate,1:1,1” can be used to set the state of the first contact) . Can i program the existing gc100 relay app so that the Itach WF2cc is polled then change the “on” or “off” to reflect the status?
Thanks!
Tim
I will put my question another way: can I send an ASCII command like “setstate,1:1,1” to my Global Cache Itach unit using Luup (considering I know the IP and Port number)? If this can be done then I should be able to send the command “getstate,1:1” and use the reply information to do something in Vera.
I would appreciate any help.
Tim
If you download the GC100 plugin, you can look at what it’s doing… If its missing specific functionality, then you can edit its files to add whatever you’re looking for, the upload it back to Vera.
Thanks for the feedback guessed - i will take a look!
I HAVE IN MY SYSTEM A VERA LITE, A GC100-12, WF2CC (THREE UNITS). THE GC100 PLUGIN WORKS FINE WITH GC-100-12 BUT WITH THE WF2CC
IT SAYS “Failed to open IO Port”
Thanks for any help anyone can provide.
TENGO EN MI SISTEMA :UN VERA LITE,UN GC100-12,TRES UNIDADES DE WF2CC, EL PLUGIN GC100 EL CUAL ME FUNCIONA CORRECTAMENTE PARA EL GC-100-12 PERO PARA EL WF2CC APARECE ESTE ERROR Failed to open IO Port
GRACIAS A QUIEN ME PUEDA AYUDAR
Has anyone have luck with this?
