I apologize in advance if this feature is already included and I missed it.
It would make things so much easier for me if in the LOGIC ACTIONS, there could be a switch where you can select a series of actions if a condition is TRUE and another set of actions if a condition is FALSE.
Right now I am programming two sets of opposite conditions on the CONDITIONS page with corresponding LOGIC ACTIONS.
I notice that I frequently make errors (that I find and correct later) programming the logic for the negative condition.
Jim
That’s a reasonable request, if I understand correctly you simply want to run another Action if the Condition is False.
Apart from using exactly the same Condition prefaced with NOT or ! I don’t think it can be done without RTS adding code to PLEG.
[quote=“zedrally, post:2, topic:198888”]That’s a reasonable request, if I understand correctly you simply want to run another Action if the Condition is False.
Apart from using exactly the same Condition prefaced with NOT or ! I don’t think it can be done without RTS adding code to PLEG.[/quote]
Correct
I can envision when you are editing a LOGIC ACTION for there to be a slider switch under OPTIONS for TRUE/FALSE
Then the below will change from TRUE Actions to FALSE Actions.
This way you can have LUA and INTERVAL times for both TRUE and FALSE conditions.
I typically set up the “false actions” as opposite conditions so when the condition becomes true, the action runs.
