What I have in mind is have the option to change how the control panels cycle. Actually, all I have in mind is “no transition;” nothing fancy.
Currently, if I press the “Home” button from one of my control panels, the home panel pushes the control panel downward. If I then press any of the control panel icons, the associated panel pushes the home panel upward. What I have in mind is an instant transition… no pushing, wiping, fading, etc.
Why: what I have in mind is to create all of the control panels to be the same: just a map of the home, either floor plan or isometric. Each control panel will do something different: lights, security, climate control, whatever. With no transition, the panels will just switch seamlessly between each other. Having any kind of transition is undesirable for this kind of setup.
Just a thought. This, by the way, would dovetail nicely with the new “forward/back” functionality in v2.3.
