Pair
Add device → WallMote Quad → Follow on-screen instruction
Wakeup device by button 100500 times, until configuration not done -
Configure
set device_file to D_SceneController1.xml
set device_json to D_CSC_4ButtonsTapHold.json
set category_num to 14
commands → configure node right now
Final steps
Settings → Wakeup interval 86400 (once in 24h)
Poll interval - 86400 (once in 24h)
Optional: add variable “urn:micasaverde-com:serviceId:ZWaveDevice1” / “DisableWakeupARR_NNU”, set it to 1 -
Associations
1 - Lifeline (to controller)
2 and 3 - tap and swipe for button 1, 4,5 - for 2 etc. -
device options:
1,1b, 0 or 1 - touch beep
2,1b, 0 or 1 - touch vibration
3,1b, 0 or 1 - disable/enable sliding
4,1b,1 or 3 - Send Central Scene Command notification or Send Central Scene Command notification + Configuration Report -
Enjoy!
If you want to enable tap-n-hold functions (assign scenes to long tap), do^
Change NumButtons variable to
8,
1-1-1=ui7_lang_tap_button 1,
2-1-2=ui7_lang_hold_button 1,
4-1-4=ui7_lang_tap_button 2,
5-1-5=ui7_lang_hold_button 2,
7-1-7=ui7_lang_tap_button 3,
8-1-8=ui7_lang_hold_button 3,
10-1-10=ui7_lang_tap_button 4,
11-1-11=ui7_lang_hold_button 4 -
Add variable urn:micasaverde-com:serviceId:SceneController1 / ButtonMapping
with value:
1-0-1,1-2-2,1-1-3,2-0-4,2-2-5,2-1-6,3-0-7,3-2-8,3-1-9,4-0-10,4-2-11,4-1-12
If you want know, why, it described here:
http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions
Nooooo, what did this do?? Changing this made the device disappear in UI7 Of course, it was working okay before, just see how your settings would impact this device.
It’s interesting though, I got 5 of these devices, they seem to work ok, even without your specific settings. Battery status is only showing (but not updating) on one of them, the others don’t show the battery.
I’m trying to get one to control my blinds by associations on the sliding commands. So far, no success yet, but I will keep trying. The blinds are the v3 iblinds EU version, it would be a great combination to have these two devices cooperate without relying on the vera controller.
The Fantem devices seem to be identical to the Wallmote devices in all aspects. But significantly cheaper.
Disappear - if make pair/unpair instead of wakeup.
Associatios can work without any settings, but after settings you can assign scenes to clicks and long-taps in Vera interface.
Hi Tmorfus.
Thanks very very much, this is hugely usefull.
I tried on the model found on aliexpress : https://fr.aliexpress.com/item/4000270345636.html?spm=a2g0s.9042311.0.0.5ea16c379K8uEe
which is FT130-C from brand Haozee and that works almost perfectly.
For the records : when launching a scene with a “Hold Press”, the scene is launched at least 2 times. Not a problem in many cases… But mine was launching a scene to toggle the state of a device… Toggle once and toggle a second time is not good
Well, if you have an idea, I would love to test it.
Thanks again.
Sylvain.
Hmm. I don’t know, how to workaround it.
M.b. we can check last scene time and allow execution only after 3-4 sec.
Yes, two small lines of lua will do the job, you’re right.
I’ll chek and I’ll tell you.
