Something came up this morning, I can’t figure out the problem.
I call it False Triggering.
Most of my switches and modules are Scene programmed, for some odd reason, this morning the blinds in our bedroom, which are connected via a Dragon Tech wall module, closed by itself, they should have been open, according to the scene parameter.
All that to say, ( What can cause a false trigger )
If you look in the logs, you should be able to see any triggered activity.
You didn’t say exactly when this happened, but my suspicion is that it happened in the wee hours of the morning. My guess is that Vera’s nightly heal operation and device reconfiguration errantly set the module to Off(closed).
[quote=“Z-Waver, post:2, topic:193673”]If you look in the logs, you should be able to see any triggered activity.
You didn’t say exactly when this happened, but my suspicion is that it happened in the wee hours of the morning. My guess is that Vera’s nightly heal operation and device reconfiguration errantly set the module to Off(closed).[/quote]
Great info. thanks
Dom
