I have made a Lua script that monitor with PingSensor if my or my wife is present. If not, it will close all the lights, music, close the blinds and lock the door.
My issue is that one in a while, I get a error on the script and Lua hangs.
I tried all kind of codes to fix that issue but since I didn’t pin point when it happends, I’m screwed.
Any thoughts?
LuaUpnp Log.
08 06/12/16 15:26:29.100 Scene::RunScene running 91 Presence <0x2bd26680>
01 06/12/16 15:26:29.101 LuaInterface::CallFunction_Scene Scene 91 failed attempt to call a nil value <0x2bd26680>
Scene Lua:
function nopresence(log)
if log == “1” then
local filewrite = io.open("/mnt/usb/lognopresence.txt", "a")
filewrite:write(os.date().. " ")
filewrite:flush()
filewrite:close()
--[[ If No one if home, flip the VShitch. --]]
local VSSebHome = assert(tostring(luup.variable_get("urn:upnp-org:serviceId:VSwitch1","Status", 847)),"1")
if log == "1" then
filewrite:write(" VSSebHome:"..VSSebHome)
filewrite:flush()
filewrite:close()
local VSTashaHome = assert(tostring(luup.variable_get("urn:upnp-org:serviceId:VSwitch1","Status", 848)),"1")
if log == "1" then
filewrite:write(" VSTashaHome:"..VSTashaHome)
filewrite:flush()
filewrite:close()
local PingSebHome = assert(tostring(luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1","Tripped", 843)),"1")
if log == "1" then
filewrite:write(" PingSebHome:"..PingSebHome)
filewrite:flush()
filewrite:close()
local PingTashaHome = assert(tostring(luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1","Tripped", 846)),"1")
if log == "1" then
filewrite:write(" PingTashaHome:"..PingTashaHome)
filewrite:flush()
filewrite:close()
local PingNotSebHome = assert(tostring(luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1","Tripped",849)),"1")
if log == "1" then
filewrite:write(" PingNotSebHome:"..PingNotSebHome)
filewrite:flush()
filewrite:close()
local PingNotTashaHome = assert(tostring(luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1","Tripped",850)),"1")
if log == "1" then
filewrite:write(" PingNotTashaHome:"..PingNotTashaHome)
filewrite:flush()
filewrite:close()
local res,mode = luup.inet.wget("http://192.168.1.146:3480/data_request?id=variableget&Variable=Mode",5)
if log == "1" then
filewrite:write(" Mode:"..mode)
filewrite:flush()
filewrite:close()
mode = assert(tostring(mode),"1")
--[[ If seb not home and reverse tripped, change status VS to 0 --]]
if (PingSebHome == "0" and PingNotSebHome == "1") then
if log == "1" then
filewrite:write(" Seb not home ")
filewrite:flush()
filewrite:close()
luup.call_action("urn:upnp-org:serviceId:VSwitch1", "SetTarget", {newTargetValue = "0"}, 847)
if (PingSebHome == "1" and PingNotSebHome == "0") then
if log == "1" then
filewrite:write(" Seb is home ")
filewrite:flush()
filewrite:close()
luup.call_action("urn:upnp-org:serviceId:VSwitch1", "SetTarget", {newTargetValue = "1"}, 847)
--[[ If Tasha not home and reverse tripped, change status VS to 0 --]]
if (PingTashaHome == "0" and PingNotTashaHome == "1") then
if log == "1" then
filewrite:write(" Tasha not home ")
filewrite:flush()
filewrite:close()
luup.call_action("urn:upnp-org:serviceId:VSwitch1", "SetTarget", {newTargetValue = "0"}, 848)
if (PingTashaHome == "1" and PingNotTashaHome == "0") then
luup.call_action("urn:upnp-org:serviceId:VSwitch1", "SetTarget", {newTargetValue = "1"}, 848)
if log == "1" then
filewrite:write(" Tasha is home ")
filewrite:flush()
filewrite:close()
if log == "1" then
filewrite:write(" check 1 ")
filewrite:flush()
filewrite:close()
if (VSSebHome == "0" and PingNotSebHome == "1") then
if (VSTashaHome == "0" and PingNotTashaHome== "1") then
if log == "1" then
filewrite:write(" Nobody home ")
filewrite:flush()
filewrite:close()
luup.call_action("urn:upnp-org:serviceId:VSwitch1", "SetTarget", {newTargetValue = "0"}, 845)
if log == “1” then
local filewrite = io.open(“/mnt/usb/lognopresence.txt”, “a”)
filewrite:write(" check 2 ")
filewrite:flush()
filewrite:close()
if log == "1" then
filewrite:write(" ", "\n")
filewrite:flush()
filewrite:close()
nopresence(“1”)
