EzMotion strange behavior
I have vera3 with the firmware 1.5.622. I try to install MiOS Update Utility Plugin before add ezmotion to my vera3 network but there is no tip if i succeed installing the plugin or not, just installing operation finished without warning , if its ok, ezmotion act only generic_io. After polling that generic_io there is a warning “Unable to get any information on node”. I am waiting suggestion. What should I do ?
Hi
The MiOS utility should appear in your installed app listing on Vera.
Regarding the EZmotion, by the sounds of things if you only have one device listed, for what is a 3 in 1 sensor then it looks like the inclusion process has not worked. Also there are 3 versions of the EZMotion sensor in circulation, with 2 possible appearances in the Vera UI, depending if it’s V1 & 2 or V3.
First things first I would ensure you have reloaded Vera a few times and refreshed the browser, if you do not get at least 3 new sensors listed (light/motion/temp) then it’s not worked correctly and I’d suggest you exclude it and then refresh/reload and include it again.
There are 2 focused threads on the versions listed above should you want to read up on others experiences - just search for EZmotion and then the version you have.
The MiOS utility doesnot appear in my installed app listing on Vera, I try to install it a few times( more than ten) . What is your suggestion ? It seems I have to solve that first.
