[ul][center][size=14pt]STATUS[/size]
It’s currently the findings of this thread and other posts in this forum (so far) that there are far too many instances of problems being experienced with Vera and the EZMotion sensor to say they are fully compatible - So for now, it’s the opinion of the author of this thread that I strongly recommend you avoid purchasing any of these units untill more test have been done and MCV and/or EZmotion have confirmed there 100% compatibility - Numerous support calls have been logged with MCV and more recently some with Express Motion, some resulted in good information/feedback, but sadly little to no improvements or fixing the underlying problem that clearly exists… [/center]
Hi All
Due to there being a number of posts created on the EZMotion, this particular post/thread is seeking to capture links to all the other posts and to also try to sumarise the problem being faced… Forums are hard enough to navigate and search at the best of time so i hope this is of help. As they say we are stronger together than we are apart…
The Situation (as I understand it) - I will update this as news come to light contribute
[list]
[li]There are two version of the original sensor, the newest version has a blue connector to allow power to be connected. Express Motion have released a new EZMotion+ which is not part of this thread[/li]
[li]Motion seems to be the only sensor that works (most of the time time) [/li]
[li]Light or Temperature readings are updated very infrequently or not at all [/li]
[li]Some products show the manufacuturer as Express Controls other show it as Ryard Ventures[/li]
[li]The device works fine under UI4, (TBC if both old and new version do)[/li]
[li]Wake Ups do not result in any updates being made, even when temp or light have changed[/li]
[li]A firmware updates are available from Homeseer, but at a cost?! [/li][/list]
Versions
[list]
[li]EZmotion - V1.x (a.k.a Homeseer HSM100)[/li]
[li]EZmotion - V2.x (a.k.a Homeseer HSM100 S2)[/li]
[li]EZmotion+ - Only here for reference, this is a new release no reports of performance yet. [/li]
[/list]
Official Calls Logged with MCV - I will update this if people can let me know if they have logged an official report with MCV
[list]
[li]parkerc = 2013-01-03[/li]
[li]LightsOn = 2012-09-21[/li]
[li]Piwtorak = 2012-12-15[/li]
[li]pgrover516 = 2012- TBD[/li]
[/list]It would be sensible to assume the more ‘official’ tickets we collectively log, the more chance we have of getting this resolved.
Known forum Threads on this products (below) - hopefully the main points are sumarised above…
HSM100 / Ezmotion 3-in-1 not working with UI5 - > [url=http://forum.micasaverde.com/index.php/topic,8899.0.html]http://forum.micasaverde.com/index.php/topic,8899.0.html[/url]
EZMotion 3-in-1 Sensor Light Sensor - >[url=http://forum.micasaverde.com/index.php/topic,12822.0.html]http://forum.micasaverde.com/index.php/topic,12822.0.html[/url]
Set Ezmotion 3 in 1 to broadcast temperature every few hours? → [url=http://forum.micasaverde.com/index.php/topic,12615.0.html]http://forum.micasaverde.com/index.php/topic,12615.0.html[/url]
New Motion HSM100-S2 sensors bad, prior model good - > [url=http://forum.micasaverde.com/index.php/topic,10937.15.html]http://forum.micasaverde.com/index.php/topic,10937.15.html[/url]
Make Vera Run Command “ZWJob_GetNodeDetails” (ezMotion 3 in 1 Sensor) - > [url=http://forum.micasaverde.com/index.php/topic,13113.0.html]http://forum.micasaverde.com/index.php/topic,13113.0.html[/url]
Ezmotion usage scenarios and EZMotion vs. new EZMotion+ - > [url=http://forum.micasaverde.com/index.php/topic,13083.0.html]http://forum.micasaverde.com/index.php/topic,13083.0.html[/url]
Re: Ezmotion 3 in 1 multi sensor, wrong behavior - > [url=http://forum.micasaverde.com/index.php/topic,12937.15.html]http://forum.micasaverde.com/index.php/topic,12937.15.html[/url]
Other Useful Information
Micasaverde Supported Hardware → [url=http://wiki.micasaverde.com/index.php/Supported_Hardware]http://wiki.micasaverde.com/index.php/Supported_Hardware[/url]
Micasaverde Wiki → [url=http://wiki.micasaverde.com/index.php/ExpressControls3in1#Known_issues]http://wiki.micasaverde.com/index.php/ExpressControls3in1#Known_issues[/url]
EZmotion Official User Guide → [url=http://www.expresscontrols.com/pdf/EZMotionOwnerManual.pdf]http://www.expresscontrols.com/pdf/EZMotionOwnerManual.pdf[/url]
EZmotion Battery Guide → [url=http://www.expresscontrols.com/pdf/EZMotionBattery.pdf]http://www.expresscontrols.com/pdf/EZMotionBattery.pdf[/url]
Homeseer EZmotion Firmware Update → [url=http://store.homeseer.com/store/HomeSeer-HSM100-Firmware-Update-Service-P982.aspx]HomeSeer | Smart Home Hubs, Switches & Sensors For Any Need and Budget
Homeseer HSM100 Manual ->[url=http://www.homeseer.com/pdfs/guides/HSM100_Release_Notes.pdf]Support Home Page | HomeSeer
Please add anything that you think is of use…
I would also politely ask other anyone reading this who stumble accross any other posts to let me know the link and if possible, try to direct that post to this particular thread,
[center]IMPORTANT
If anyone has the EZmotion 3in1 working as it is supposed to, please post your findings here too[/ul]
[/center]
