EzloPi Plugin for Home Assistant is now live
Smart home enthusiasts, rejoice! We’re thrilled to announce that EzloPi, our powerful open-source IoT development platform, is now fully compatible with Home Assistant. With the release of the EzloPi Home Assistant integration, we’re opening the door to a world of seamless control, powerful automation, and unparalleled customization for your ESP devices—all while giving you the freedom to operate locally.
What is EzloPi?
EzloPi is the ultimate open-source IoT development platform designed to turn ESP boards into smart boards, complete with:
  • Local Control Control your ESP-based devices without relying on the cloud.
  • Cloud connectivity for remote control and monitoring.
  • Mobile app integration for on-the-go automation.
  • A no-code configuration tool (ezStart) for quick setup.
  • Open-source firmware to give developers ultimate flexibility.
With EzloPi, even those without coding experience can make their devices smarter and integrate them into larger ecosystems. Developers, on the other hand, will enjoy advanced features and tools to push the boundaries of IoT.
Why EzloPi + Home Assistant = The Perfect Match
Home Assistant is already one of the most versatile and beloved platforms for home automation. By integrating EzloPi, we’re empowering users with an amazing new capability: the ability to sense and control their environment more easily than ever before. Here’s what this integration brings to the table:
  1. Effortless Local Control
  • Control your ESP-based devices without relying on the cloud, ensuring fast, reliable, and secure communication within your local network.
  1. Enhanced Automation
  • Leverage Home Assistant’s robust automation engine to create advanced workflows using EzloPi-enabled devices.
  • Example: Combine EzloPi’s sensors with Home Assistant to detect environmental changes, trigger alerts, or control other smart devices.
  1. Flexible Customization
  • Use EzloPi’s open-source framework to modify and enhance devices exactly to your needs. Whether you’re creating a custom smart thermostat or an advanced security system, the possibilities are endless.
  1. No-Code Setup with Powerful Options
  • Thanks to EzloPi’s user-friendly tools, you can get started without a line of code, but advanced users can dig into the firmware for ultimate customization.
  1. Cost-Effective Smart Home Solutions
  • With affordable ESP boards and open-source tools, EzloPi and Home Assistant make building a smart home accessible to everyone.
What You Can Do with EzloPi and Home Assistant
  • Monitor Your Home’s Environment
    • Measure temperature, humidity, light, and more with EzloPi-enabled sensors, and view the data in real time on your Home Assistant dashboard.
  • Control Devices with Precision
    • Use EzloPi to control lights, fans, or other appliances, and sync them with Home Assistant’s scenes and automations.
  • Integrate with Existing Ecosystems
    • Add EzloPi devices to your existing Home Assistant network to expand its capabilities.
  • Run Everything Locally
    • With this integration, there’s no need for cloud dependency. Your smart home remains private, responsive, and always available, even during internet outages.
Why Open Source Matters
The EzloPi Home Assistant integration is completely open source, giving developers and hobbyists the ability to:
  • Learn from and improve the platform.
  • Collaborate with a community of like-minded innovators.
  • Adapt the platform to fit unique use cases.
You can explore the code and contribute to the project on GitHub.
Sense and Control the World Around You with Ease
With EzloPi’s compatibility with Home Assistant, the barriers to creating a truly intelligent and customized smart home are a thing of the past. Whether you’re an experienced developer or just starting your smart home journey, EzloPi provides the tools and freedom you need to bring your ideas to life.
Join us in redefining what’s possible in home automation. Dive into the code, start building, and explore a future where controlling your environment is as easy as imagining it.
Visit our GitHub page to get started today!
The later versions of EzloPi firmware that support this new integration with Home Assistant seems to have broken or locked out access to the Web Sockets API on the EzloPi via local direct LAN access, as it has broken my integration of EzloPi controllers with Reactor.
