EzloPi Firmware Update V4.4.13(203)
Fixes & Improvements
  • Added ADC DeInit function and memory cleanup.
  • Added the delete_service context function and addressed potential memory leak warnings.
  • Error returns have been added to initialization functions to handle potential failures.
  • Fixed a null pointer dereference issue in the scenes populate functionality.
  • Fixed a possible null pointer dereference issue with the house_mode_id_array.
  • Fixed invalid log10() argument issues in various MQ sensor detectors.
  • Fixed issue with hub.nma.register.repeat implementation to prevent firmware crashes.
  • Fixed a bug where the object did not have a parent in the BME680 sensor library.
  • Fixed undefined behavior caused by shifting a 32-bit value by 56 bits in the factory module.
  • Fixed a null pointer dereference issue in Core Modes.
  • Fixed an arrayIndexOutOfBounds error in ezlopi_core_processes.
  • File and function headers have been annotated with relevant information, including parameters and return variables.
  • Templates have been applied to all source files coded by Ezlo.
  • Added a JSON file for saving settings.
Thank you for your continued support, and please let us know if you encounter any issues or have feedback!
Release notes link:
