New Version of EzloPi is now out.
You can use this Open Source Firmware to turn any hardware device into a Smart Hardware device. Its ESP firmware at the moment, more to come.
here is the full Source code and an example of how to build a Temperature Sensor.
We will continue to expand the platform and add more examples.
Ezlo polls the ESP32 with a GET and then the IP template parses the response string to stuff the temperature reading into a temp probe device.
The code to read the sensor is trivial once you load the Dallas Semi library, just a couple lines to initialize and read the probe(s). Would be easy to make this native in Ezlo Pi.
sensors.requestTemperatures(); // Goes out and polls all the attached DS18B20 Sensors attached and each gets a row in the output
for (int i = 0; i < sensors.getDeviceCount(); i++) {
row = "Temperature P ";
row += String(i + 1);
@curiousB I was just sent some ESP32 boards to play around with, not sure of their exact type yet. Other than they are 30 pin.
But I might be asking you some questions in the coming weeks if you don’t mind? As reading some of the “EzloPi” threads you seem pretty knowledgeable on this topic.
I need to order some breadboards and pinout cables though, any recommendation on the type of breadboards to use ? I also need to order various sensors and peripherals to try, like buttons, relays, temp sensors, presence sensors etc, before I can get started.
