I am trying to get my SonOff devices to report their status back to my virtual devices that I use to control them on my Ezlo Secure hub when the physical button is pushed. I had this working on my old Vera Secure but since the upgrade I cannot get the devices to push the status update to the new hub. Below is how I am trying to configure my rule. If you guys have any ideas I am open to suggestions.
on Relay#Switch do
if [Relay#Switch]=0
gpio,13,1
else
gpio,13,0
endif
endon
on Button#Switch do
if [Relay#Switch]=0
gpio,13,1
gpio,12,1
SendToHTTP 192.168.1.3,17000,/v1/method/hub.item.value.set?_id=610971e793ac1d140ba40fb2&value_bool=true
else
gpio,13,0
gpio,12,0
SendToHTTP 192.168.1.3,17000,/v1/method/hub.item.value.set?_id=610971e793ac1d140ba40fb2&value_bool=false
endif
endon
Hello @rlargent,
This code is written for the SonOff hub, correct?
I’m curious to know why you have commas instead of colons after the IP address and the port. I mean something like this: SendToHTTP 192.168.1.3:17000/v1/method/hub.item.value.set?_id=610971e793ac1d140ba40fb2&value_bool=true
Have you tried this request by itself? Does it work as expected?
I guess I am just hopeful that someone else has either already done this or they are up to the challenge of figuring it out. I already have a virtual device on my Ezlo hub sending commands to turn the device on/off with a scene but haven’t figured out how to push the status from the device back to the Ezlo hub.
They work perfectly from a browser.
This is how I am controlling the lights via scenes and virtual devices.
I am working now to get the ESPEasy flashed Sonoff to send this command back to the Ezlo hub when the physical button is pushed. As #Oscar.Morales pointed out it is weird that the syntax in the command reference requires a comma between the IP and port number. I’ve tried it both ways from the rules section on the Sonoff without luck.
I found the issue! It wasn’t with my command syntax at all…
It appears that in the device’s config I had to change the protocol from “Generic HTTP” to “Domoticz HTTP”.
All is working now. Thanks for the assist.
