I have an Ezlo hub and periodically when I attempt to control a device, the device is non-responsive. Meaning, it doesn’t turn on or off (for example). Occasionally, I’ll see a message in the Vera app that says “Device failed to communicate”. These are devices that are plugged in, and I the latest one was within 10 feet of the hub.
If I reboot the hub, the devices come back online, so it does not appear to be a device issue, but more of a hub issue.
I have numerous Z-wave repeaters and about 50 devices connected to the hub, so there should be plenty of coverage.
Any suggestions on how to make the hub more reliable?
Thanks.
