See subject. Once that’s answered, how do I ssh into it? My Ezlo Plus will suddently stop responding, about once a day. Power cycling ‘fixes’ it, but that’s not a good fix…
Can you not just do it on your router and set a static LAN IP for the Ezlo Plus hub? That’s what I did.
You can use Putty application to SSH in to the Ezlo Hub.
Username is root password is the WIFI password on the Sticker on the Ezlo hub.
