No idea when it happened as I do not look at the Ezlo Hub that often, but it is now stuck in an endless startup loop. Version 2.0.23.1817.1 (where are the release notes?). This is from the ha-luad.log and shows for each restart, about every minute.
2021-12-16 18:20:06.568506 MSG : a module ‘zwave’ is already present
2021-12-16 18:20:06.568952 DEBUG: A plugin’s script HUB:zwave/scripts/helpers/for_each_zwave_node_info has been loaded
2021-12-16 18:20:06.569415 MSG : a module ‘zwave’ is already present
2021-12-16 18:20:06.572120 DEBUG: A plugin’s script HUB:zwave/scripts/helpers/create_device_type_id has been loaded
2021-12-16 18:20:06.572578 DEBUG: A plugin’s script HUB:zwave/scripts/helpers/get_device_info has been loaded
2021-12-16 18:20:06.572901 MSG : Plugin script reader: Could not find plugin file /opt/firmware/plugins/zwave/scripts/model/devices/devices_info/generated/816_768_41735.lua error: No such file or directory
2021-12-16 18:20:06.573416 DEBUG: A plugin’s script HUB:zwave/scripts/model/devices/devices_info/base_info has been loaded
Unsupported AGI command
2021-12-16 18:20:06.576416 MSG : Plugin script reader: Could not find plugin file /opt/firmware/plugins/zwave/scripts/model/devices/devices_info/generated/816_768_41734.lua error: No such file or directory
2021-12-16 18:20:06.579523 DEBUG: A plugin’s script HUB:zwave/scripts/model/devices/devices_info/generated/600_3_4231 has been loaded
2021-12-16 18:20:06.584636 DEBUG: A plugin’s script HUB:zwave/scripts/model/devices/devices_info/generated/271_1536_4096 has been loaded
Segmentation fault (core dumped)
**** luad Restarted at Thu Dec 16 18:20:11 CET 2021
Turing of and on again did not help.
