Ezlo Plus and Ezlo Secure hubs are running the HTTPS server on port 17000.
HTTPS server API documentation:
HTTP_server_API.pdf (62.0 KB)
Dummy guide for using the HTTP / HTTPS Server API on the Ezlo hubs.
Can you give me an example on GET ?
With Vera I can use a HTTP command sent from another system, like this to retrieve the value of a temperature sensor:
http://VERA-IP/port_3480/data_request?id=variableget&DeviceNum=537&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature
How do you do the same with the Ezlo HTTP API ?
The documentation example wasn’t clear to me.
I have another question regarding that is not clear to me.
how can i send http command from ezlo to 3rd party system with dim level of the dimmer, something like http://xxx.xxx.xxx.xxx/3rdparty_url_dimlevel={_id,value}
Think you can send HTTP commands OUT from scenes in the Vera mobile app for iOS.
Don’t think the Android Vera mobile app has that ability yet.
Yes i can send but i know how to send a command for example when dimmer changes send a fixed value and not to send current level of the dimmer.
Hi @eonnet,
Just as with Vera you would require a bit of Lua for that. However, that is currently not possible in a scene. You would have to make a whole plugin for that.
Cheers Rene
I figured as much
now i’m using 3rd party system to ezlo, and ezlo → openLuup → Reactor ->http command to 3rd party system but its a hit and miss, after reboot of openluup reactor stops responding… it does not trip… but i still didn’t play long enough and searched what is the problem in order to ask for help.
