Has this become possible yet? To install new ezlo firmware on Vera hubs?
Hello @Plus,
It is possible to install the Linux Firmware that Ezlo controllers use on Vera Edge controllers only. You can find more information on this post here.
Regards!
Please excuse my newness to the forum, if I get the posting location, etc., wrong.
I just transitioned from a Vera Edge to an Ezlo Plus controller. In doing so, I lost the use of my 2 GoControl GD00Z-4 Garage Door controllers. That’s number 245 on the list of supported devices (if I understand correctly). Vera support says sorry - that device is not supported. I challenged that, and they said that the supported device list were for Vera Edge, and not necessarily for Ezlo Plus. Further, they said that it is unlikely to will be for the Ezlo Plus. Too old.
Is this true?
If so, how do I know what is supported on the Ezlo controller, versus the Vera?
Further, how many other surprises am I likely to run into?
Hi @David_Forsberg , can you tell us the firmware of your ezlo plus . Also did you try removing the devices via API and pairing them back as Generic zwave devices ? Do you see the devices in your devices list at all ? What is the exact error you get ?
