Postive news, now that the plugin marketplace is functional again, I was able to reinstall the hue plugin (after a ezlo hub firmware reset - different story). Plugin version is now 1.0.27 and the previously reported delay is again.
Total time between motion detection and hue light turning on is roughly 0.5 seconds.
Osman, if that’s directed at me than no - thinks have improved massively with version 1.0.27. I think autocorrect created a bit of a mix up, where it stats ‘delay is again’, it should read ‘delay is gone’.
Is anyone having trouble with the Hue plugin not adding devices? I installed and configured the plugin (v 1.0.27) and the bridge now shows up as a device. However, no connected hue lights are showing up and I don’t see how to manually add them. The devices do show up in the Hue app, so I’m sure they are connected to the bridge.
That worked, thank you! I had deleted the Hue Bridge and re-added/configured (pressing the button within 5 seconds) multiple times. This time, I deleted the plugin entirely and started over. That seemed to do the trick. Thanks for your help!
