Hi guys
Can you do some things for us automatically, for a newbie like me and for our future uses please?
Guys, an update about simple one line http commands.
We are planning to add possibility to enable/disable of authentification in our HTTP API.
In this case it will be possible to disable auth and remove all security by your own choice and have the same simple one line commands how it works now on Vera hubs.
If you need more security, it will be possible to enable it through api request.
Hallelujah ![]()
Hi @Oleh
Good news in an ocean of questions for http request
Very happy to read that
Many thanks
It is in progress now.
You will have a choice between security and simplicity.
Guys, an annouce of our next release…
As we discussed before, here is the API description for:
- Enable or disable insecure access (WS and HTTP as opposed to secure WSS and HTTPS).
You may want to enable it if self-signed certificates used on controller are not supported in your client software. - Enable or disable anonymous access (without authentication via hub.offline.login.ui for requests via WS API or HTTP basic authentication for requests via HTTP API)
- Notify controller about new local access data availability.
- Login to Controller via direct connection as user
- Login to Controller via direct connection as controller
It will be possible to enable/disable basic auth and remove all security by own choice and have the same simple one line commands how it works now on Vera hubs.
If you need security, it will be possible to enable it through api request.
It will be available in our next Thursday’s release
LocalModeCommands.pdf (92.3 KB)
I can’t see hub.offline.login.ui in the online API Tool.
So how do we turn off authentication for one line HTTP requests ?
Hi
Can you explain how you setup the authorisation in Postman please ?
I’m getting a Error: socket hang up
Using a Raspberry Pi to send the command but from my Atom I am just getting this response and its not working:
curl: (52) Empty reply from server
Curl version on the Pi
Seems Curl is already the latest version
I guess this doesn’t work on the Atom as yet.
You are right, its not implemented yet for Atom, we are working on it.
Oleh
Please can you help answer my question here about turning off authentication for the HTTP API
Thank you.
Hi @cw-kid,
You have to use the API Tool https://apitool.ezlo.com/, select your Ezlo Plus hub, click Connect, then API Calls “Not Listed” and enter the below in the Textbox.
"method": "hub.offline.anonymous_access.enabled.set",
"id": "12345",
"params": { "enabled": true }
Now check with hub.info.get.
Cheers Rene
Brilliant thanks Rene, I will try it later !
So the ID number can be anything ?
Yes the id is useful for websocket communication with the hub as the reply will include the same id. As websockets are asynchronous the replies may be received out of order. The id will tell the receiver what the reply is for if order is relevant.
Cheers Rene
hub.offline.anonymous_access.enabled.set and hub.offline.insecure_access.enabled.set are now set to true.
Do you also need to enable this one ? hub.offline.login.ui
Example from the document looks like I need a token which I don’t currently have.
"method": "hub.offline.login.ui",
"id": "_ID_",
"params": {
"user":"user.identifier",
"token":"Hs87Kns41106743NMS2"
try to include the --http1.1 option, and maybe --insecure.
Cheers Rene
The curl options should be specified before the url argument. Also, you can use the --verbose option to see what is happening under the hood. I also see that you are trying standard http vs https presumably because you are trying to set the hub to insecure local mode. What happens if you use the following?
curl --http1.1 --insecure --verbose http://192.168.0.11:17000/v1/method/hub/info/get
curl --http1.1 --insecure --verbose https://192.168.0.11:17000/v1/method/hub/info/get
Hi
Thanks for your help !
Yes I am trying to use HTTP rather than HTTPS and the auth token.
HTTP
HTTPS
* Expire in 0 ms for 6 (transfer 0xe09880)
* Trying 192.168.0.11...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0xe09880)
* Connected to 192.168.0.11 (192.168.0.11) port 17000 (#0)
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: none
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server accepted to use http/1.1
* Server certificate:
* subject: C=RO; ST=Iasi; L=Iasi; O=controller; OU=d026af70-7f32-11ea-ab2d-b7c43c5254eb; CN=90000400; emailAddress=sysadmins@ezlo.com
* start date: Aug 28 15:48:35 2020 GMT
* expire date: Feb 22 15:48:35 2021 GMT
* issuer: C=RO; ST=Iasi; L=Iasi; O=location; OU=8098afb0-a7da-11e9-ab53-05964c0ff1e4; CN=clas.ezlo.com; emailAddress=sysadmins@ezlo.com
* SSL certificate verify result: EE certificate key too weak (66), continuing anyway.
> GET /v1/method/hub/info/get HTTP/1.1
> Host: 192.168.0.11:17000
> User-Agent: curl/7.64.0
> Accept: */*
< HTTP/1.1 200 OK
< content-type: application/json
< connection: close
HTTP/1.1 200 OK
connection: close
* TLSv1.2 (IN), TLS alert, close notify (256):
* Closing connection 0
{"error":null,"id":"5f50df88120bab679022945e","result":{"architecture":"armv7l","build":{"branch":"at","builder":"@6f94411cdbcf","commit":"e218a385eccb4ef8bcf0c1d1","time":"2020-08-28T13:27:44+0000"},"firmware":"1.3.1028.3","kernel":"4.19.75","localtime":"2020-09-03T13:20:24+0100","location":{"latitude":54.0043029785156,"longitude":54.0043029785156,"state":"customAll","timezone":"Europe/London"},"model":"h2.1","offlineAnonymousAccess":true,"offlineInsecureAccess":true,"serial":"9pi@raspberrypi:~ $
