Ezlo hubs local/offline mode commands:
- hub.offline.credentials.updated
Notify controller about new local access data availability. - hub.offline.login.ui
Login to Controller via direct connection as user - hub.offline.login.hub
Login to Controller via direct connection as controller - hub.offline.anonymous_access.enabled.set
Enable or disable anonymous access - hub.offline.insecure_access.enabled.set
Enable or disable insecure access (WS and HTTP as opposed to secure WSS and HTTPS)
Detailed description of local/offline mode commands:
LocalModeCommands.pdf (98.1 KB)
