I have a Z-Wave appliance plug (Xenon SM-a701a) that when first paired it was correctly detected by the Ezlo Plus as just an ON / OFF plug. However much later the system decided it was no longer a plug and that it should be a Water Valve with OPEN / CLOSE buttons instead.
I then unpaired the device from the controller and paired it again but it still thinks its a Water Value its not its a plug.
On Vera firmware hubs in UI7 web GUI we can manually change things to change the device type.
By going in to the devices Advanced - Params area we can change these items.
device_type
device_file
impl_file
device_json
category_num
subcategory_num
There seems to be no way to have this type of control over a device on the Ezlo controller and no way to manually force it to change it to the correct device type.
