Ezlo - How to create a virtual Door & Window Sensor device?
Hi
How do you create a virtual Door & Window Sensor device ? I cannot see one in the drop down menu.
How do you remove virtual links if not needed any more, the devices settings tab does not remove this link?
i think there may still be a bug where it does not remove / delete virtual devices ?
Correction seems to work OK for me i just deleted a Virtual device OK .
Go in to the web UI and then Settings Devices. Find the virtual device in question and then click Settings on that and then Remove Device
Tried that and did not remove device.
What version do you have at the bottom ?
And what is your controllers firmware version ?
Not sure, my controller is on a newer beta version than yours.
I know in the past there was a bug where you could not delete a virtual device.
Maybe it got fixed on the new versions ?
The only other way was to use the command line script to delete a device as in this thread here
Not a big deal but would like to delete the icon from my Dashboard since it’s not used anymore.
It doesn’t seem to be implemented yet. I just created this feature request for you: ECS-1150.
Your controller was just flagged to the last LIVE build. The update should start upon reboot.
Reboot worked, Virtual Device Deleted ok.
Thank You Much.
