Fixes & Improvements
- Door lock labels in the Mios dashboard have been updated for consistency, changing “Open” to “Unlocked”.
- Fixed functionality for the Eltako ESB62NP-IP shading actuator, ensuring correct status display and command control.
- The tile for the Eltako ESB62NP-IP shading actuator now matches the product design specification.
- Incorrect text displayed on Thermostat Modes for Radio Thermostat CT32 has been corrected.
- Fixed an issue with the Yeelight plugin where the color temperature slider incorrectly moved from the max. cold value position.
- Fixed an issue with the RGB color wheel’s inconsistent position in the Yeelight plugin.
- Air quality sensor tile updated for design consistency with revised color and slider.
- Text for the “Clear” button in the “Filter” section of the “Dashboard” is now centered.
- “Other modes” in the thermostat tile is now properly centered.
Thank you for your continued support, and please let us know if you encounter any issues or have feedback!
Release notes link:
