When will there be an app of web-based portal for the Ezlo that i can access outside my house? DId i miss it?
Hello @DRagu,
I’m sorry if I’m not understanding your question correctly. The VeraMobile app and Ezlogic web portal can grant you access to your Ezlo controllers from anywhere in the world as long as you have an internet connection and the controller is online. It is not necessary to be in the same location/network to access your system. If you are having any issues with the remote access, please let us know at support@ezlo.com.
Kind regards!
You can already access it remotely from your IOS or Android app remotely.
you can also use the Web Portal we have http://ezlogic.mios.com/ .
I tried this.
The URL above takes you to a login with no option to create a sign in. My Ezlo username and password does not work.
@Sloanish Are you logging in with the account you enter the app?
it works with Ezlo hubs only, not the old Vera hubs for now.
I am using the same login as the app.
It does not allow me to login and there is not facility for lost password.
I have the same problem. I have a Ezlo and two veras.
