Ezlo API, how to get item value?
I’ve seen the question in many other threads, but never seen an answer.
How do I get the valueFormatted of a temperature sensor by requesting a local http get to the Ezlo Plus?
(I’m already set up with offlineAnonymousAccess and can set values etc)
You have to use the hub.items.list method and include the device ID of the temp sensor. That will return a json with the valueFormatted. See API - Ezlo API Documentation
In http that would be something like:
https://:17000/v1/method/hub/items/list?deviceIds=
(the parameter deviceIds is not yet correct, having trouble to find the right use.)
Cheers Rene
The main goal is to have the Ezlo Plus to update a virtual sensor on my Vera Secure when value changes (like luup.variable_watch) but the lack of examples and me not understanding the docs for the new firmware stops me from doing that.
One would think since there is hub.item.value.set there would be a hub.item.value.get but not that I have found in the docs.
So my idéa is to poll the sensor from Vera in a scene with a simple http request.
I can get the value with the api tool with hub.data.list:
    "api": "1.0",
    "method": "hub.data.list",
    "id": "_id_",
    "params": {
       "items":{
            "ids":["5fd35167129e0711ffa44a75"], "fields": { "include":["valueFormatted"] }
But I can’t figure out how to filter nested objects in a url.
I guess it’s quite simple to script this request and extract the value from the json response if you know how, but I’m still a novice in Lua.
It seems we are stuck at the same thing then. I asked the developers but no reply yet.
Hi @Crille,
I was reading past the most powerful request “v1/request”. With that you can post the exact json data to the hub.
https://<ip>:17000/v1/request -d '{ "method": "hub.data.list", "id": "16081108876", "params": {"items":{"ids":["5f747430124c411719483753"],"fields":{"include":["valueFormatted"]}}}}'
Cheers Rene
Rene
I tried this command in Postman, to get the temperature off a Fibaro motion sensor, but I get an error:
https://192.168.0.11:17000/v1/request -d '{"method": "hub.data.list", "id": "5f749301120bab105e88c463", "params": {"items":{"ids":["5f749301120bab105e88c464"],"fields":{"include":["valueFormatted"]}}}}'
I tried HTTP and HTTPS.
You have to use a POST request, not a GET.
I tried POST also.
Let me try again.
You can use GET to run a scene or control a device on the Ezlo Plus hub OK.
I think you need to look at the PostMan documentation on how to specify the data in the POST request. The example I gave is for a curl command.
I get this with Curl
There was an extra space in front of the “method”. I removed the space and now see this:
If I remove all the spaces from within the command like this:
curl --insecure --http1.1 https://192.168.0.11:17000/v1/request -d '{"method":"hub.data.list","id":"5f749301120bab105e88c463","params":{"items":{"ids":["5f749301120bab105e88c464"],"fields":{"include":["valueFormatted"]}}}}'
I don’t get any errors now but I get no value back either.
Its the same with this command and using the other ID number “1608117651467” , still no value returned.
curl --insecure --http1.1 https://192.168.0.11:17000/v1/request -d '{"method":"hub.data.list","id":"1608117651467","params":{"items":{"ids":["5f749301120bab105e88c464"],"fields":{"include":["valueFormatted"]}}}}'
Thats great, now I just have to figure out how to send that from Vera and parse the json response :thinking:
I see you are using curl in a Windows command shell. That handles quotes differently than Unix/Linux. The single quote does not help to make the rest of the command a simple string. You need a lot more quotes. Some thing like:
-d "{ """method""":"""hub.data.list""", """id""":"""1234"""..... }"
As always, I ended up doing what I know best and wrote a powershell script to do the job.
I wish there was a simple url to get the value, then I could poll directly from Vera instead.
Indeed.
Just tried it from my Pi instead and that does indeed work OK and return the temperature value.
Example Curl Command:
curl --insecure --http1.1 https://192.168.0.11:17000/v1/request -d '{"method": "hub.data.list", "id": "608801a4120bab172e9c4f66", "params": {"items":{"ids":["608801a4120bab172e9c4f67"],"fields":{"include":["valueFormatted"]}}}}'
This is the first thread on the forum I believe with a working example of retrieving values via the Ezlo API !
I’ve asked this same question several times and never gotten any response or reply from the Ezlo devs about it.
Its a shame its not as easy as Vera Luup Requests and a single one line HTTP command can be used with no method payload needed.
For the record here is a Vera command example:
http://192.168.0.12/port_3480/data_request?id=variableget&DeviceNum=537&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature
Much easier…
So if it needs POST to retrieve a device value from the HTTP API, I assume its not possible to have a simple one line HTTP command to return the data like you can with Vera Luup Requests ?
I’ve just worked out how to get it working in Postman application for testing however.
Create a new request
In the URL enter
https://EZLO-IP:17000/v1/request
Select “Headers”
Then add a new Key of “Content-Type”
And then add a new value of “application/json”
Click the drop down box next to URL and change it to POST
Now select “Body” then “Raw” and paste in your data
Data Example:
Click the “Send” button, in the Body you should then see your response. I was looking up the value of a temperature sensor.
Give your request a name and save it.
