EZ-MQTTRelay
Easy (EZ) Node.js app that relays all ui_broadcast messages from Ezlo hubs discovered on the local area network to an MQTT broker. For convenience, the app is deployed as a dockerized app for Intel/AMD and ARM platforms.
All messages are posted to the MQTT topic Ezlo/<hub serial>/<msg_subclass>/<deviceId>
Motivation
Example EZ-App to illustrate the simplicity of observing Ezlo Hub ui_broadcast messages using the ezlo-hub-kit SDK.
This EZ-App also appeals to Ezlo users that would like to push their Ezlo controller/hub data to a time-series database (e.g. InfluxDB) for graphical reporting and analysis (e.g. Grafana).
- Start the dockerized EZ-MQTTRelay
$ docker run -it --network host \
--name ez-mqtt-relay \
-e miosUser=<MIOS Portal User> \
-e miosPassword=<MIOS Password> \
-e mqttBrokerUrl=<Local Broker URL> \
ghcr.io/bblacey/ez-mqttrelay
- Verify that the application starts successfully, connects to the MQTT broker, discovers the local Ezlo hubs and receives
ui_broadcastmessages.- NOTE: You can force a hub to publish a
ui_broadcastmessage simply by activating a device on an Ezlo hub using the Vera application (e.g. turn a light on or off, change house mode, etc.)
Connected to mqtt broker mqtt://192.168.0.104
Observing: 90000369, architecture: armv7l , model: h2.1 , firmware: 2.0.7.1313.2, uptime: 0d 13h 35m 2s
Observing: 90000330, architecture: armv7l , model: h2.1 , firmware: 2.0.7.1313.2, uptime: 0d 14h 50m 55s
Observing: 45006642, architecture: mips , model: g150 , firmware: 2.0.5.1213.2, uptime: 0d 8h 46m 32s
Observing: 70060017, architecture: esp32 , model: ATOM32 , firmware: 0.8.528, uptime: 4d 10h 11m 16s
Observing: 70060095, architecture: esp32 , model: ATOM32 , firmware: 0.8.528, uptime: 0d 23h 15m 57s
Observing: 92000014, architecture: armv7l , model: h2_secure.1 , firmware: 2.0.7.1313.16, uptime: 2d 8h 9m 5s
Mon, 11 Jan 2021 01:29:14 GMT 70060095:ui_broadcast {
msg_subclass: 'hub.item.updated',
msg_id: 1841934316,
result: {
_id: 'DA79ACF7',
deviceId: 'ZC5F00207',
deviceName: 'Landscape 1-4',
deviceCategory: 'dimmable_light',
deviceSubcategory: 'dimmable_colored',
serviceNotification: false,
roomName: 'Exterior',
userNotification: false,
notifications: null,
valueType: 'power',
value: 20.2,
scale: 'watt',
syncNotification: false
- Confirm that the messages displayed in the docker logs reach the MQTT broker. There are many ways to accomplish this but one simple method is to open a new terminal window and use the
mosquitto_subcommand to subscribe to theEzlo/#MQTT topic. In the excerpt below, the MQTT broker is running on host 192.168.0.104.
$ $ mosquitto_sub -t 'Ezlo/#' -v -h 192.168.0.104
Ezlo/70060095/hub.item.updated/ZC5F00207 {"id":"ui_broadcast","msg_subclass":"hub.item.updated","msg_id":1841934316,"result":{"_id":"DA79ACF7","deviceId":"ZC5F00207","deviceName":"Landscape 1-4","deviceCategory":"dimmable_light","deviceSubcategory":"dimmable_colored","serviceNotification":false,"roomName":"Exterior","userNotification":false,"notifications":null,"name":"electric_meter_watt","valueType":"power","value":20.2,"scale":"watt","syncNotification":false}}
If everything is operating correctly, ui_broadcast messages will appear in both the ez-mqttrelay docker log file and the mosquitto_sub terminal window simultaneously.
At this point, you can terminate the sample run by typing control-c.
Production use
To run the dockerized EZ-MQTTRelay as a persistent process you can use docker-compose (recommended) or run the docker container ‘detached’ as a background process.
First, for either option, create or download config.env and edit the file to to use your MIOS portal username, password and MQTT broker URL.
For those users who prefer to use docker-compose, you can download the docker-compose.yml and start the relay with.
docker-compose up -d .
Compose users may find the EZ-Apps github project useful. It comprises a docker-compose file with unified config files need to run the EZ-App suite with a simple docker-compose up -d.
docker run --detatch (alternative)
Start the relay in detached mode.
$ docker run --detach --network host \
--name ez-mqttrelay \
--env-file config.env \
The App
Take a look at the Source code for the app - it is really simple and illustrates the benefits of an expressive ezlo-hub-kit for rapid application development.
Futures
The scope for this EZ-App was intentionally limited for this initial ezlo-hub-kit proof-of-concept example app but it would be very straight-forward for fellow developers to extend it and submit pull requests. The obvious features are supporting MQTT broker authentication and extending the relay to be bi-directional (i.e. execute hub actions).
1. MQTT Authentication
In the interest of brevity, the example app does not include MQTT authentication but it is a straight forward extension. Implementing this feature would simply entail adding the MQTT Broker username and password to the config.env file and modifying the example app to retrieve the environment variables and pass them to the MQTT broker connect() method.
2. Bi-directional relay
Extending the ez-MQTTRelay to be bi-directional (e.g. perform hub actions) is also straight-forward because the ezlo-hub-kit provides methods to run scenes and control devices.
The relay would need to subscribe to incoming messages using the MQTT client.subscribe('Ezlo/#', cb()) and add a message handler using the client.on('message', function()) method to forward the actions to the hub. In additiona, an MQTT message scheme would need to be defined to represent hub actions.
As an illustation, consider the MQTT messsage scheme below:
MQTT Message Schema (illustration)
Ezlo/<premises>/<hub|ALL>/<action>/<id>/<arguments>
The following MQTT (RunScene and SetItem) messages would map to the ezlo-hub-kit as follows:
Run a scene
Ezlo/Home/90000369/RunScene/Sleep => hub[90000369].scene('Sleep').then((scene) => runScene(scene._id))
Turn off a device
Ezlo/Home/90000369/SetItem/5fd39c49129ded1201c7e122/false => hub[90000369].setItem(5fd39c49129ded1201c7e122, false)
Dim a light to 50%
Ezlo/Home/90000369/SetItem/5fd39c49129ded1201c7e123/false => hub[90000369].setItem(5fd39c49129ded1201c7e123, 50)
I will happily accept GitHub pull requests that extend EZ-MQTTRelay in this direction.
Head over to the EZ-MQTTRelay Github repo to get started!
