Has anyone gotten the Express Controls 3-in-1 sensor to work with any of the luup releases. Whatever I have tried, I cannot see any of the embedded devices in the sensor.
If you have gotten it to work, what was the procedure. I Have tried to follow the instructions on the wiki, but it had no effect.
It used to work with the pre-luup releases.
Attached is screendumps of how it looks in setup and on the dashboard. The 3-in-1 is the device called Combo Device in the screendumps
mine working well (X4) in ver 939, on initial installation one showed up as generic IO and turns out it was too far from the base and needed a wired device nearby, after correcting that I excluded then paired it again, and it worked fine
Yes, exclude and then include again. As I’ve said before, the ONLY way these things configure is for me to sit the 3-in-1 on top of Vera while it configures–and this takes a while–and then move it back to where I want it positioned. Push the blue button again when it’s in position so it will talk to its new neighbors. They seem to configure consistently with 949 and 958 versions.
