So my cheap USB-Extender, over Cat5 cabling, arrived today. I’ve been running a few tests on it before wiring it properly to Vera.
I plan to use this to achieve the following effects, as time permits:
[ul][li]Extend my USB-Serial (PL-2303) Adapter from Vera down to the Family room to control the TV, then write a Luup Driver for the TV’s core functions[/li]
[li]Add a [powered] Hub to support Multiple USB-Serial adapters to drive other components like the Amp, DirecTivo etc, write Luup drivers for them[/li]
[li]Add a USBUIRT for everything that can’t be controlled by a Serial interface (AppleTV, etc)[/li][/ul]
I’ll use this thread to document the progress I make for others that might be interested in a relatively cheap solution when:
[ul][li]you can’t get Vera “close” to the [wired] things it has to Control.[/li]
[li]you either have spare Cat5 Cabling to the target, or you don’t mind pulling some through your walls[/li][/ul]
Total cost so far ~US$20 (including Shipping, not including Cat5 Cable):
[ul][li]No-name USB Extender US$9.90 (via eBay “Buy it Now” from Hong Kong, incl Shipping)[/li]
[li]No-name USB Non-powered 4-Port Hub $0.00 (Came free with IPEVO Skype phone I bought a yr back)[/li]
[li]Bytecc BT-DB925 USB-Serial Adapter ~US$11.00 shipped (see http://wiki.micasaverde.com/index.php/USBSerial_Supported_Hardware for details)[/li][/ul]
So I ran a series of tests on the Extender to see how long a cable run it could really support:
10ft Cat5
[ul][li]USB Mouse worked fine (attached to a PC)[/li]
[li]Western Digital Passport 160 2.5" Hard Drive worked fine, albeit at USB1.1 speeds (attached to a PC)[/li][/ul]
25ft Cat5
[li]Western Digital Passport 160 2.5" Hard Drive couldn’t get enough power, light flashed[/li]
[li]Bytecc BT-DB925 USB-Serial Adapter worked fine (attached to Vera)[/li][/ul]
Hopefully tomorrow I’ll have time to try the in-wall wiring, which is about 35ft away from Vera, but so far the progress looks good. For the “Vera connected” test, I was using the non-powered 4x Port USB hub. There was likely some power loss as I’m also hanging my Alarm Panel’s USB Interface off the same connector.
At some point I’m expecting to have to use a Powered USB Hub, but so far I’m having luck without doing that, esp since it’ll increase the cost of the solution compared to the alternatives
