Hi all,
I’m about to buy a Vera and start with home automation (first steps: automation of lights and other power using equipment and security by means of some motion sensors, door-window sensors and may be IP camera).
I read through this forum and also others very thoroughly (took my quite some hours but I learned a lot). My biggest question is should I choose for (only) zwave devices also for home security OR buy a dedicated alarm system that can be integrated in Vera. I read a lot of times the latter is the best choice for mainly reliability and costs.
dedicated alarm system ?
I live in Holland and DSC system (I read very positive experiences about DSC) is not or hardly available and the same counts more and less also for Honeywell. So that limits my choice to Visonic Powermax. Concerning costs this would be a negative thing because a starter kit costs already more than EUR 500 and the wireless motion sensors (EUR 65-70 per piece) and door-window sensors (EUR 40-45 per piece) of Visonic are not cheaper (on the contrary more expensive…) than the Zwave sensors here in Holland. I cannot work with wired systems in my existing house.
Zwave devices ?
I read a lot of negative experiences with the zwave motion sensors and door-window sensors. But in lot of cases people did not install them right or firmware (device and/or Vera) had to be adapted. Which is often the case with new technologies/products…
My questions to all you that have at least half a year experience with one or more of the zwave motion sensors and door-window sensors
What device(s) do/did you use ? What is your experience at this moment, what about false triggers, need to reset the sensor once in while AND battery life ? Would you recommend me to use them as use in security system OR choose for a dedicated alarm system ?
My interest goes to the devices of Everspring, Fibaro (only door-window at this moment), Vision and Philiotech (about Aeon Labs and EZmotion I only have read negative experiences…)
