I have a problem with a remote switch. This switch worked perfectly for 1 years, no problem. Today, When I press the Switch On or Off, the led on the switch blink rapid for 3-4 sec, and the light do not light. If I try with the switch associate with the LTM-5, the light work. If I send a command from web, all is ok. Why the led switch flash and not work? I don’t see error in the vera3, I check all node, all seem ok
