I just picked up an LCD-2 off ebay but it didn’t come with a power “cube”. I know I need 120VAC to 12VDC but the documentation doesn’t specify anything further (like amperage). I emailed Evolve support about buying a psu by itself, but I’m hoping I can just get an off-the-shelf transformer/converter so I can wire this whole thing up and get cracking on setting it up.
Anyone have any ideas?
Thanks.
I just put my LCD-1 in the wall, so can’t check the specs, but here’s an image of the same supply that came with mine:
[url=http://www.skywalker.com/images/products/large/EVO300A_add3.jpg]http://www.skywalker.com/images/products/large/EVO300A_add3.jpg[/url]
I would think you should be able to use that to glean the necessary info, right? I’m also assuming the LCD-2 has the same requirements.
Cheers,
Geoff
