Everspring ST814 Threshold Limit Warning
I have a problem with the ST814. When the device hits one of it’s thresholds, (20%-90% for humidity) the device only reports the threshold value to group 1, and not the actual humidity… It’s really dry here in the winter so 20% hits quite often… Anyone else got this problem?
All comments welcome!.
Looks like the default thresholds are set at outer edges of the sensor’s specified range (20%-90%).
Turns out that the actual humidity was less than 20 so naturally the device reported the lowest value possible… :slight_smile: Hence there was nothing wrong with the device, it’s working like a charm now.
