Everspring ST814 Temperature/Humidity Detector using vera 3 as the system controller only displays whole numbers for temperature readings can someone help me with the setting up for displaying temperature readings to one decimal place
It’s not possible. This is a limitation of the Vera code - I raised it as a bug with MCV about 18 months ago…
http://bugs.mios.com/view.php?id=1817
http://forum.micasaverde.com/index.php/topic,7798.0.html
http://forum.micasaverde.com/index.php/topic,10791.0.html
Chris
