Is there anyone using Everspring SF812 Smoke Detector with Vera3 F/W: 1.5.408? When I pushed the test button, I found the device was tripped. However, the green man icon remained unchanged. I remembered that it was working fine ( ie: green man icon changed to red running man icon when it was tripped )in previus firmware. Or I should downgrade the firmware to test it again. Thanks for advices.
This is pretty much a useless piece of kit; its Z-Wave capabilities and reporting are very poor. If you search the forum you will find other posts about it.
