everspring AN145 keeps flickering
GOt a couple of everspring an145 modules. When purchased and paired with vera all worked fine. But after a few months they keep flickeing (on/off) after I run the scene ‘lights on’.
I returend 2 already, but I’m wondering if I can do anything about this? Anybody else had the same problem?
Answers are much appreciated!
Cheers.
I had 8 of these, they all started flickering within 1 year.
I threw the hardware out of its casing and replaced it with Fibaro switches…these fit inside the AN145 case nicely…
[quote=“Jackpost, post:2, topic:175168”]I had 8 of these, they all started flickering within 1 year.
I threw the hardware out of its casing and replaced it with Fibaro switches…these fit inside the AN145 case nicely…[/quote]
Ah, so it isn’t just me. These things are just faulty by design. You use the 2,15kw or 1x3kw sitches from fibaro?
Using the 2 x 1.5Kw version works but would be wasting 1 1.5Kw channel…
The dimmer works though…
Having a push button to switch the fibaro manually works as well but the tricky part is the find a switch that is shallow enough too fit…
Mine is still under warranty… I might just return it for now.
But, keep you posted if I insert the fibaro switch… Quite curious myself about this tho.
Cheers
This seems to be quite a common problem, I believe I’ve had about 5 replaced out of 10 of them. The others have been fine and there does not seem to be a relation to the loads they are controlling either. As long as you can send them back and get a replacement you should be ok, I realise that is a pain but at least you are not loosing out. There is clearly some sort of fault that kicks in with them randomly at some point in their life.
