hi,
so I have a setup at home which works perfectly.
I have a setup at a separate location,which has 2 devices: the exact same thermostat than at home and an IR repeater.
I’ve setup eventwatcher using an external config file using the same values as home, except different device ID for the thermostat:
cat /www/EWextras.conf
3.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature
3.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint
3.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeStatus
3.urn:micasaverde-com:serviceId:HVAC_OperatingState1.ModeState
to check that I have the right device ID and config, I pulled the logs for this device:
grep 'device: 3' /tmp/log/cmh/LuaUPnP.log | awk '{print $8}' | sort -u
urn:micasaverde-com:serviceId:HaDevice1
urn:micasaverde-com:serviceId:ZWaveDevice1
urn:upnp-org:serviceId:HVAC_FanOperatingMode1
and, to be sure it’s actually recording the temperature, I pulled them out of the logs:
grep 'device: 3' /tmp/log/cmh/LuaUPnP.log | grep CurrentTemperature
06 07/10/15 11:32:06.849 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 78 now: 78 #hooks: 1 upnp: 0 skip: 0 v:0xba5810/NONE duplicate:1 <0x776a6520>
06 07/10/15 11:35:02.799 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 78 now: 78 #hooks: 1 upnp: 0 skip: 0 v:0x954820/NONE duplicate:1 <0x77840520>
06 07/10/15 11:46:30.039 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 78 now: 79 #hooks: 1 upnp: 0 skip: 0 v:0xd6c7c8/NONE duplicate:0 <0x76ffa520>
06 07/10/15 12:00:26.740 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 79 now: 79 #hooks: 1 upnp: 0 skip: 0 v:0x79fac0/NONE duplicate:1 <0x76f42520>
06 07/10/15 12:12:08.056 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 79 now: 79 #hooks: 2 upnp: 0 skip: 0 v:0x773ac0/NONE duplicate:1 <0x77544520>
06 07/10/15 12:14:49.266 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 79 now: 79 #hooks: 2 upnp: 0 skip: 0 v:0x773ac0/NONE duplicate:1 <0x77544520>
06 07/10/15 12:43:57.841 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 79 now: 79 #hooks: 2 upnp: 0 skip: 0 v:0x773ac0/NONE duplicate:1 <0x77544520>
06 07/10/15 12:47:37.851 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 79 now: 79 #hooks: 2 upnp: 0 skip: 0 v:0xac17f8/NONE duplicate:1 <0x777c0520>
06 07/10/15 12:50:24.301 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 79 now: 79 #hooks: 2 upnp: 0 skip: 0 v:0xac17f8/NONE duplicate:1 <0x777c0520>
and yet ip:3480/data_request?id=lr_EventWatcher&plot=3&variable=CurrentTemperature returns nothing.
and when trying to get the logs out, all Isee is the RESTART :
Date/Time Class Device No. Device Name Variable Value Argument
1 2015-07-10, 12:47:31.184 E 0 Vera RESTART
and here’s the list of watched variables:
Device No. Device Name Service Variable Room
3 Thermostat TemperatureSensor1 CurrentTemperature /www/EWextras.conf
3 Thermostat UserOperatingMode1 ModeStatus /www/EWextras.conf
3 Thermostat Heat CurrentSetpoint /www/EWextras.conf
3 Thermostat OperatingState1 ModeState /www/EWextras.conf
even weirder, CPU reporting works just fine.
so,clearly,I’m doing something wrong, but what?
