Of course, the [u]real[/u] problem appears to be that you can't turn off verbose logging - or at least that doesn't work for me.
Ah! I see, trying it in the latest firmware version, that it does work - this would seem to be a viable way to reduce logging activity. What happens now is that the “[tt]retries 2 failed https://0.0.0.0/event/event/event[/tt]” seems to take up most of the log (although, of course, they happen no more frequently.)
As I said, work is in progress to handle this correctly.
Great, thanks. We’re here to help you out, so don’t hesitate to ask.
1) SYSLOG server config - do I need to setup a syslog server somewhere? If so how?
No, totally optional. If you have to ask about it, you don't need it. Some people just can't live without it. It's one way to get data off Vera and into a proper reporting system.
2) USB/LOG locations - I can't get the USB stick to work with my Edge.. So not sure where to put logs?
You can store logs locally on Vera - I have just such an arrangement on my Vera Edge for testing, but it's best to keep archive sizes to a minimum. An alternative is to install a system called CIFS which enables you to mount network storage devices (if you have any.) Your USB issue is a separate thing that I can't help with, but others out there seem to have this going OK.
DataYours looks ideal for what I want if I can get it configured.
At least start with a few watched variables and local storage. Then, if it's what you want, you can work on better storage options.
Good luck.[/quote]
Ok back I go to give it another try! I only want to watch temperature and humidity. I can’t see that taking up much log space even over the log run. I probably get 30-40 temp readings per day. If it is being efficiently stored it will be a long time before I even hit a few hundred MB of data. Does your tool automatically overwrite the log file once it hits the cap?
No dice re-installing it. I had installed and uninstalled it yesterday. Now during reinstall it seems to hang and then app doesn’t show up in the apps list or the device list. I rebooted vera and same issue. Do I need to manually clean something up?
Actually - what I mainly installed EventWatcher for was to monitor battery status and using PLEG (or something else) alarm when one got too low. Any pointers for a newbie to get something like that going?
Whilst [tt]EventWatcher[/tt] will produce a report of battery status for all such devices, it’s not really going to help you with using PLEG to alarm when one goes low. I imagine that you CAN do this with PLEG on its own - all the battery levels are already accessible to it - but I don’t know, because I don’t use PLEG.
That is the latest in the App Store… it’s definitely time for an update, but a bit busy with other things at the moment. You might download the Lua file attached to this post [url=http://forum.micasaverde.com/index.php/topic,30428.msg216997.html#msg216997]http://forum.micasaverde.com/index.php/topic,30428.msg216997.html#msg216997[/url], which has the latest functionality and bug fixes.
Do not, whatever you do, try the Alternate Event Server functionality. This is not working correctly on UI7.
@akbooer, question I seem to have a memory leak or something (e.g. logs) are slowly eating up my free memory which eventually cause a LUA restart. Is there anyway of see which apps or process is the culprit? Mike
Apart from wanton vandalism, it’s actually quite hard, if not impossible, to make a true ‘memory leak’ in a Lua app. You can, of course, just create lots of large objects, which will use up memory.
The memory leaks come, I believe, from the C or C++ bits of Luup. Why it was written that way, I’ve no idea, it’s really not necessary. My own implementation of luup, openLuup, is written entirely in Lua and doesn’t have memory leaks. But I digress.
EventWatcher itself monitors its own memory, and, in extremis, you could add a similar short snippet of code to any plugin to report what it’s using.
@akbooer, you’ve perked my interest with you statement of adding a short snippet of code… pray tell what would that code snip-it be and where within the plugin would one attach-it to? I’ve just pruned my non-used / non-essential plugins in the hopes that I’ve eradicated the memory culprit : and “yes you too can win the Lottery”… I have one other possible item that I’ve done recently (within the month) which was to add a new USB memory stick for my logs, what I don’t know is it being utilized correctly. Mike
EventWatcher itself monitors its own memory, and, in extremes, you could add a similar short snippet of code to any plugin to report what it's using.
I do this with DataYours (see attachment).
You’d have to rescale cpu usage, because it doesn’t do multiple plots on different axes.
Or just export to Excel or the like.
