For the garage door locked scenario, create a scene, add an event, and select your door as your device. For event type, select “A door is opened or closed”, and under which mode, select “closed”. Name the event, and then under commands, select whatever lights you want to turn off and set them to OFF. Save the scene and test it.
For the garage door unlocked scenario, are you saying you want the light to come on if you unlock it from the inside, or when you unlock it by typing in the code? Also, for “and” statements, you need to be prepared to do write some luup code. You can use the same steps as above, but select “opened” for “which mode” in the event section. Additionally, you’de need to add a luup scene, drop in the code below, and click update. Save your scene and test it.
if (os.date(‘*t’,os.time())[“hour”] >= 18) then
return false
Haven’t tested this code - at the office now, but it should work. This should work between the hours of 6pm and midnight. To get more sophisticated, you can check one of the many posts/threads on the forums about sunset/sunrise - or see the lua code that I believe Javier created.
Also, it’s been a while since I’ve messed around with the “door is opened or closed” event type, but when I first got the lock, that event type actually functioned as door is unlocked or locked (from the inside)
first, the second parameter in [tt]os.date()[/tt] defaults to the current time, so it’s not necessary to include a call to [tt]os.time()[/tt]. In other words:
os.date('*t', os.time())
is exactly the same as:
os.date('*t')
second: on table lookups, if the key if a simple string, with just letters, numbers and the ‘_’, and it doesn’t start by a number, it can be written as a ‘field’. so:
table["field"]
can be written as:
table.field
with this two tips, the code snippet is reduced to:
if (os.date('*t').hour >= 18) then
return false
which I find a lot more readable.
If you want to test for a range, you can use a local variable, for example to prevent the scene to run between 8pm and 2am, you can write:
local time = os.date('*t')
if (time.hour >=20 or time.hour < 2) then
return false
If you want to test for hours and minutes, it’s better to convert the full time to seconds. in the timeutils module i’ve written ([url=http://code.mios.com/svn_public/mios_genericutils/timeutils.lua]http://code.mios.com/svn_public/mios_genericutils/timeutils.lua[/url]), there are some useful functions, so you can write:
require "timeutils"
local time = timeutils.dayseconds()
if time >= timeutils.to_secs("08:30pm") and time <= timeutils.to_secs("09:15pm") then
return false
I’ve started to port this calculations to Lua; but it’s not as simple as it seems. What I’ve got so far is to calculate the Sun’s position at any given time (or ‘now’ by default), check http://code.mios.com/trac/mios_genericutils/wiki/TimeUtils
@Javier: Thanks for the pointer to your code. If this is still a work in progress, how does Vera figure out what time to use when one selects “At Sunset” in the GUI scene tool?
it does similar calculations, but it’s deep in the C++ code. I want to refactor it and port to Lua. Besides, it’s a little different when you want to do it for any given day and not necessarily just ‘next sunrise/sunset’ as the current code does.
