i have eth1 hooked up to my router and can i setup eth2 for a wired ip cam
You should be able to!
I use mine from time to time for various things without issue. I have mine also downstream of my router and have my Vera manually configured and set so that it knows its a switch and just acts like one. I presume this should also work when set automatically configure also!
thanks
