/etc/cmh-ludl for ProgramLogic Plugins
Richard,
The following ProgramLogic associated files are in the /etc/cmh-ludl directory of my Vera 3 with firmware version 1.5.622 I previously had the Program Logic Timer Switch Plugin installed on my system but removed it since I am able to do everything I need using Program Logic Event Generator v6.9 with Program Logic Core 6.91. What files in the below list can I remove from /etc/cmh-ludl and continue to run Program Logic Event Generator v6.9 with Program Logic Core 6.91?
[ol][li]D_ProgramLogic.json.lzo[/li]
[li]D_ProgramLogic.xml.lzo[/li]
[li]D_ProgramLogicC.xml.lzoenc[/li]
[li]D_ProgramLogicEG.json.lzoenc[/li]
[li]D_ProgramLogicEG.xml.lzoenc[/li]
[li]D_ProgramLogicTS.json.lzoenc[/li]
[li]D_ProgramLogicTS.xml.lzoenc[/li]
[li]I_ProgramLogic.xml.lzo[/li]
[li]I_ProgramLogicEG.xml.lzoenc[/li]
[li]I_ProgramLogicTS.xml.lzoenc[/li]
[li]J_ProgramLogic.js.lzo[/li]
[li]J_ProgramLogicC.js.lzoenc[/li]
[li]J_ProgramLogicC-UI5.js.lzoenc[/li]
[li]J_ProgramLogicC-UI6.js.lzoenc[/li]
[li]J_ProgramLogicEG.js.lzoenc[/li]
[li]J_ProgramLogicEG-UI5.js.lzoenc[/li]
[li]J_ProgramLogicEG-UI6.js.lzoenc[/li]
[li]J_ProgramLogicTS.js.lzoenc[/li]
[li]J_ProgramLogicTS-UI6.js.lzoenc[/li]
[li]L_ProgramLogic.lua[/li]
[li]L_ProgramLogicCCP.lua.lzoenc[/li]
[li]L_ProgramLogicCEE.lua.lzoenc[/li]
[li]L_ProgramLogicCP.lua[/li]
[li]L_ProgramLogicCRG.lua.lzoenc[/li]
[li]L_ProgramLogicEE.lua[/li]
[li]L_ProgramLogicEG.lua.lzoenc[/li]
[li]L_ProgramLogicTS.lua.lzoenc[/li]
[li]ProgramLogicEG.png[/li]
[li]S_ProgramLogic.xml.lzo[/li]
[li]S_ProgramLogicC.xml.lzo[/li]
[li]S_ProgramLogicEG.xml.lzo[/li]
[li]S_ProgramLogicTS.xml.lzoenc[/li][/ol]
If you do not need the Program Logic Timer Switch … you can delete the following file from /etc/cmh-ludl
ProgramLogicTS
Thanks Richard.
