Errors on ezlogic.MiOS.com
Hi. When I log in I get a box that says “unknown method”
Then when I try to configure the myQ plugin I get a blank page. If I look at the source code it says to enable JavaScript.
I get the same error on an iPhone going to the web site.
If I try to edit a meshbot I will sometimes get this error.
Anyone have these issue or know how to fix the errors???
Am I on the wrong site?
Hello @RonnieBoyOK ,
You are using the correct website. There is a known issue related to plugins configuration button that has been already fixed and will be published with the new Ezlogic version within the next few days. I’ll let you know as soon as the fix is live.
I’ll send you a PM in order to check your setup.
The update that contains the fix is live, you should be able to configure your plugin now.
I got it configured.
Glad to read!
