Hi Richard -
I’ve had this happen on two different Veras so thought I’d better send it to you. One was an upgrade from VeraAlerts 3.x and the other from 4.1 to 4.3
Upon trying to open the app I get these messages on each menu:
Opening va_Control…
Opening va_Profiles…
Error parsing Profiles
I’ve seen those kinds of messages on PLEG and VeraAlerts but generally if you click to another menu and back it all loads up fine. This time I got these messages on the Notification Configuration screen. After clicking through each one it presents a completely empty Notifications table.
Device: 5 Scene Obj:6 Trigger Index:0
Device: 3 Scene Obj:9 Trigger Index:0
Device: 29 Scene Obj:12 Trigger Index:0
continues for every device in the notifications table.
Any thoughts?
Thanks again for all of the help. It is much appreciated.
Edit:
tried to run a Report and it just comes up with a blank screen.
Restored a backup from yesterday that has 4.1. Now having the exact problem with that version as well.
I’ve been fooling around with this for the last couple hours and might have figured out what’s going on. I’m not positive but it seems that if I add a second profile for pushover that it then takes the Profiles in Advanced and makes it ‘nil’. Once this happens it either stops sending push notifications, or worst case it won’t let you back into the plugin with the errors from the previous post. For what it’s worth, both profiles have a separate pushover user id and pushover app id.
Delete the contents in Profiles (Advanced Tab)
Restart Vera …
Setup your profiles and Test before you save or Reload Vera. (Do not reload Vera with incomplete Profile)
Thanks Richard. I’ve done those same steps many times. Without fail if I create a second Pushover profile it will eventually change the Profile field on the Advanced tab to ‘nil’ and then everything dies. The only way to get it back to working is to empty all fields and start over.
Am I correct that I should be able to have two different pushover profiles, both with different user id and application ids?
For what it’s worth, I had the same problem with v6.31 today. I tried switching between tabs, reloading Vera, and refreshing my browser several times but that didn’t fix it. I was able to get it working again by forcing an update to the installation files using the link below.
