I just updated to 4.4 , But I can not get it to work. Previously I used 2.2 ( I think ) without any problems.
Updating> went without a problem.
Initially I didn’t understand what the profiles exactly did, but I now understand this is like overiding the default email adres for the users in for example the smtp option.
-created a profile for my samsung with the ID
-created a profile for smtp: using “from” my own email adress and changed the “vera@gmail.com” also to my own adress.
-in setup, I hooked up myself with profile (android) and the other user ( which is also for me) with the smtp-email profile.
-I switched a licht on and off ( which has the notification for both users) >> no effect.
-rebooted vera and clicked ctrl+F5
only error messages:
A popup when I click the profiles tab : “unable to parse profiles”
many popups like these when I click the “notification configuration”
“Device: 102 Scene Obj:62 Trigger Index:0”
“Device: 74 Scene Obj:54 Trigger Index:0”
What to do ? , I cannot open any tab anymore , it just shows me the “loading Bar”
I allready tried to remove the plugin and installed it again via the GUI , but it was all the same.
I uninstalled the programm again , and reinstalled.
Just made a profile for my samsung phone >> I got again a TTS alert on my android, Happy again!
Than I tried to made an email profile , there it all went wrong, when I saved it , reloaded the browser , the whole vera alerts didn’t do anything. also no TTS message on the android phone anymore.
Also the error pop ups ( see post above) came up again.
I cannot change any setting anymore,vera alerts just shows methe “loading bar”
attachment 1.jpg are the settings (without password) in the profile tab.
I think it’s working now
Maybe it is because I did it remotely from a slow internet connection? I just did it via a remote desktop session, no errors so far.
A question in the meanwhile, when I set up a profile, can I in the “to” section put more email adresses?
The TO: field in the profile can only hold a single recipient.
However from LUA or the advanced tab in a scene you can set the recipients in the form of: xxx@abc.com,foo@baz.com, …
will work.
You can make multiple profiles and associate multiple email profiles with a Vera User.
Sending Emails via the LUUP libraries is a pain, it requires special processing.
I will add to the list to support multiple recipients in the TO: field.
For now I wil make for every user a profile, due to the different email adresses.
I want it the other way arround, 1 profile which sends to multiple email adresses which I can select for multiple users :-)
The idea behind it:
I have quite some Ip camera’s in and arround my house ( using blue iris). Since I am lots of time away from home, no one is taking care of my house, hence the camera’s so I can take a look now and than.
I also have smoke detectors installed in most of the rooms ( zwave capable), when smoke is detected a trigger is send and a notification to my family , friends etc ,with a link to the camera’s and a username and password.
This username and password has to change whenever an email for smoke detection is send out. That means I have to change all profiles.
It would be easy iuf there is one profile , which sends to all the emailadresses I want. and in the subject I put the username and password. There is not a lot of room for error than.
I have about 10 smoke detectors , each of them give a notification , and with that people know where the notification came from.
That would still mean 10x changing the notification name to have the password and username in it.
Or when I make a scene?PLEG which triggers a notification , that would mean there is no way anymore to know where the notification originated from.
The easiest way would be to insert in the vera-alerts “to” option multiple emailadresses ( which is for the moment not possible) Or the second easiest ( I think) to have every user a profile and in the subject change every time the message I want to send ( username and password), for the moment there are 5 email adresses where it needs to be send.
[quote=“RichardTSchaefer, post:8, topic:178651”]The TO: field in the profile can only hold a single recipient.
will work.
I will add to the list to support multiple recipients in the TO: field.[/quote]
This does not work.
