So this is new. On my Ezlo controller, I can no longer manually register a plugin via the
/opt/firmware/bin/ha-infocmd hub.extensions.custom_plugin.register plugin_name
command. I get the following error in the ha-extensions_manager.log:
ERROR: Error during loading gateway config from json
ERROR: Plugin: fail to get a gateway part of the plugin’s config
I get this when trying to register our plugin, in a version that worked in the past, or with a copy of the ezlo_wol plugin.
Anyone else seeing anything like this?
