Error "Unfortunately Imperihome Lite has stopped" after upgrade to 3.0.2
Recently I keep getting error “Unfortunately Imperihome Lite has stopped”, and Imperihome stops.
when I try to control some of the devices (lights in the livingroom) via Imperihome via Dashboard.
No error happens when I control via the Flat devices list.
I have Imperihome Pro (licensed)
It seems to happen after updating yesterday to version 3.0.2
Looks like a bug,probably to soon to expect a solution, but I thought I report it anyway.
Hi.
Same here, pro user. On most if my devices i can not even go to the flat list.
Since my family only has accea via imperihome it is a big problem. Can you also send an email to support from imperihome. So they at least know I am nkt the only one.
I need to work on a backup, for when this happens again.
Thanks,
Cor
[quote=“Cor, post:2, topic:197055”]…
…[/quote]
Done…
Just recieved a reply that they fixed it: version 3.0.3 is out.
It was a problem with locked widgets.
I will disable auto update from now on :-\
Cor
Same here, but now my question is:
where can I find that new release 3.0.3 ?
Obviously I have auto update switched on, but where can I find that setting ?
Go to your playstore, seatch for imperihome (lite) again . there you have the options uninstall and update ( instead of install) now.
Cor
OK, that’s the way to do it then…
Just an hour ago I strated Iperihome on my phone, and it came with a popup to upgrade to 3.0.3.
That is what I did, and all works fine…
